Date/Time: Sun, 04 Oct 2026 08:45:11 +0000
how to create symbols on a chart like in this screenshot?
View Count: 1252
| [2015-01-20 19:46:16] |
| jivetrader - Posts: 410 |
1. which studies can create indicators like the triangles that are printed in a row along the top or bottom of the screen? does this require ACSIL? 2. which studies can print a marker right on the bar, at a specific location based on a volume event, like the pink triangles overlayed onto the bars? thanks |
| [2015-01-21 04:22:29] |
1. Any study can draw triangles just by changing to one of those Draw Styles. 2. Look at using the Color Bar Based on Alert Condition study. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-01-21 05:11:48] |
yes i am pretty familiar with the study how do i use it to plot a straight line row of triangles at the bottom of the chart if let's say, if one MA is above another ? |
