Date/Time: Fri, 22 Nov 2024 14:01:32 +0000
weekly and monthly charts built from a custom session possible?
View Count: 1671
[2013-05-23 00:21:38] |
User22396 - Posts: 191 |
is it possible to build weekly and monthly charts from say a pit session or custom session? like when ya build a daily chart (1 day) using 'intraday only' and 1 day... thanks |
[2013-05-23 05:15:25] |
This will not work well when using Intraday data because there is no way to control the beginning of the week or month.
[2013-05-23 11:23:55] |
thanks for the reply so SC builds weekly and monthly ONLY from the datafeed's globex(24hr session)daily bars? i use iqfeed and i assume they do not provide daily pit session data to then create weekly and monthly charts? thanks again b |
[2013-05-23 16:38:23] |
Yes, this is correct in regards to both questions.
