Date/Time: Mon, 05 Oct 2026 05:49:06 +0000
Server-side OCO and bracket order with CQG
View Count: 2916
| [2015-01-19 21:54:25] |
| User10995 - Posts: 2 |
Dear Sirs, I understand this a quite recent feature, but is it possible to use Sierra with CQG to get the full server-side OCO and bracket orders by an AMP Clearing account? If not, where I can find a list of brokers allowing that, for emini futures? Thanks in adavance |
| [2015-01-19 22:25:09] |
In the latest versions of Sierra Chart, server-side OCO is supported with CQG but not full bracket orders. However, once the main order fills, the OCO Attached Orders are managed server side.
| [2015-01-20 05:56:41] |
So, if I undertsand well, it is fine using an accont at AMP powered by CQG; I ccan put an order OCO like: ES is currently at 1000, buy at 1002 OR sell at 998, but it is not server side; if I just put an order buy at 1002, and once filled automatically put a limit at 1004 for profit, withha sell at 998 for stop loss, these two are server side. Correct? Thanks for your reply |
| [2015-01-20 17:53:01] |
An OCO order entered from Sierra Chart will be server-side with CQG. And Attached Orders once the parent order fills, will have server-side OCO. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
