Date/Time: Sun, 22 Dec 2024 15:34:46 +0000
Visualizing adjusted Stop-Orders on Chart?
View Count: 1066
[2015-01-19 13:25:33]
User51760 - Posts: 108
Hello Support Team,
having used a trading platform in the past where it was possible to visualize Stop-Orders which were adjusted managing the position. These visualization showed on the chart like lines - please refer to the attached imagefile.
I wonder if it is possible to show these lines on the Chart with Sierra Chart - or if it is possible programming something doing it.
Maybe there is an indicator/study already existing.
Thank you for your consideration,
Best,
Chris
imagevisualizing_trailed_stops.png / V - Attached On 2015-01-19 13:25:14 UTC - Size: 199.34 KB - 399 views
[2015-01-19 17:13:28]
We do not see this as something that would be added.
It could be done as a custom study though. However, this is not within the scope of our support to provide help with this.
[2015-01-19 18:48:04]
Thank you for your answer.
I am assuming, a custom study would be done via ACSIL, am I correct?
I cannot find any developers anymore on Sierra Chart website https://www.sierrachart.com/index.php?page=doc/links.php#Other
Could you provide a link to find developers coding Sierra Chart custom studies?
[2015-01-21 17:00:08]
alex@n - Posts: 20
List of Third Party Sierra Chart Study and System Programmers
http://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.html#ThirdPartyList
[2015-01-22 03:26:45]
Yes, custom study would be done with ACSIL. What it would do is get the order details and place the order price into a study subgraph. Actually this might be a rather simple implementation. However, a simple implementation really will not be completely reliable.
One question is what happens when you have multiple orders, how do you tell the study which order to plot.
So our general analysis of this, is that it is possible but not easy to do reliably.
Date Time Of Last Edit: 2015-01-22 03:27:09
[2015-01-22 15:48:11]
@ Sierra Chart Team, thank you for you responding...
@ alex@n: thanks a lot for providing the link - I saved it for further reference,
Best,
Chris
