Date/Time: Fri, 22 Nov 2024 18:43:49 +0000
Error opening the InternalOrderID.data file for writing
View Count: 1735
[2013-05-22 21:57:12]
keymoo - Posts: 9
I've just created a new PC and installed Sierra Chart. The first line in my log says this:
Error opening the InternalOrderID.data file for writing. Windows error code 5: Access is denied. | 2013-05-22 21:55:44
Any idea on how to fix?
[2013-05-22 22:34:11]
Go to that file in the Sierra Chart folder on your system. Right-click on it and select Properties and make sure the "Read only" option is disabled.
[2013-05-22 22:46:18]
keymoo - Posts: 9
The read only attribute is not set. Anything else? Something to do with UAC? I'm using Windows Server 2008 R2 DataCenter Edition.
[2013-05-22 22:52:40]
Make sure the Windows account that you are logged into, has read and write access to the Sierra Chart folder.
[2013-05-24 12:41:48]
keymoo - Posts: 9
Thanks that worked. I got this problem because I installed SierraChart under the Administrator account. I then logged on with my "normal" account (which is a member of local admins).
