Date/Time: Sun, 22 Dec 2024 16:53:28 +0000
Multiple SC Instances
View Count: 819
[2015-01-19 09:20:37] |
User78442 - Posts: 260 |
I am running 3x instances; Main (OEC Fix), SC Historical & Forex Data. I want to open a USDJPY chart from the Forex data but on the Chart Settings Symbol list it only shows the OEC and Historical Data options. Any ideas?
[2015-01-19 18:03:02] |
Refer to the documentation here about this kind of problem: https://www.sierrachart.com/index.php?page=doc/MultipleServices.html#SharingWithAdminAccess Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
