Date/Time: Sun, 22 Dec 2024 15:57:48 +0000
Add/remove exchanges.
View Count: 871
[2015-01-19 06:39:12] |
bambaldino - Posts: 11 |
Hallo, can I change exchange from "Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts per 15,75$" to "Full CME Group (CME, CBOT, COMEX, NYMEX)for nonprofessional Trading accounts per 3,25$". First I saw this possibility, but now is not there. Many thanks. Peter Date Time Of Last Edit: 2015-01-19 06:40:29
[2015-01-19 09:38:12] |
You first need to deactivate: Full CME Group (CME, CBOT, COMEX, NYMEX) with Market Depth for nonprofessional Trading accounts per 15,75$" And then next month you need to activate: "Full CME Group (CME, CBOT, COMEX, NYMEX)for nonprofessional Trading accounts per 3,25$". Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-19 11:15:27] |
Thank you very much. Best regards Peter |
