Date/Time: Sun, 22 Dec 2024 16:44:19 +0000
Out of Bounds
View Count: 1282
[2015-01-19 06:34:26] |
User78442 - Posts: 260 |
I keep having this message? any ideas? Base Graph DateTime: Out of bounds array error at Index -1039 | 2015-01-19 06:32:09 * Base Graph DateTime: Out of bounds array error at Index -1037 | 2015-01-19 06:32:09 * Base Graph DateTime: Out of bounds array error at Index -1035 | 2015-01-19 06:32:09 * Base Graph DateTime: Out of bounds array error at Index -1033 | 2015-01-19 06:32:09 * Base Graph DateTime: Out of bounds array error at Index -1031 | 2015-01-19 06:32:09 * Base Graph DateTime: Out of bounds array error at Index -1041 | 2015-01-19 06:32:09 * Base Graph DateTime: Out of bounds array error at Index -1027 | 2015-01-19 06:32:09 * |
[2015-01-19 17:06:03] |
We need to get the Chartbook which is causing these messages so we can test it. Privately attach it here by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Only attach one Chartbook and no others. Only attach the one which is causing these messages. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
