Date/Time: Wed, 27 Nov 2024 23:48:49 +0000
Change font TPO letters
View Count: 2369
[2015-01-18 16:30:16] |
Mack - Posts: 83 |
I have a tough time changing the font for the TPO letters. In Global Settings > Graphic Settings. - Chart Text Font = Arial Bold 12 In Global Settings > Tool Settings - Global Chart Drawing Font = Arial Bold 12 For this chart, the option Use Global Graphic Settings Instead of These Settings is enabled. Still, the TPO letters are displayed in Tahoma (I think). http://www.sierrachart.com/image.php?l=1421598486505.png How should you change the font of the TPO letters? Date Time Of Last Edit: 2015-01-18 16:31:55
[2015-01-18 22:05:06] |
We have looked into this and the font face cannot be changed but the font size can be changed through TPO Profile Chart study Input settings. What we will do in the next release, is make the font face the same as the chart text font. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-06-19 00:51:58] |
TemetNosce101 - Posts: 1 |
Hi, is this fixed or fonts still cannot be adjusted? Thanks in advance.
[2023-06-20 13:44:49] |
Sierra_Chart Engineering - Posts: 17198 |
Fonts are fully configurable. Refer to: Graphics Settings: Fonts and Text Appearance Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
