Date/Time: Sun, 22 Dec 2024 11:18:52 +0000
[User Discussion] - Write up/down ticks in the TICK AV/BV fields. Vote
View Count: 973
[2015-01-18 12:18:10] |
maxima120 - Posts: 144 |
I think AV/BV fields are wasted for many market stats symbols. For example TICK has meaningless information of 0 and 1 in these fields.. I am convinced that users can benefit from better information. I would like to ask SC to write up and down ticks which were used to calculate each TICK record. I think the change in question will take 5 min for a developer but will mean a lot for a user.. Please vote here for this feature to be implemented! |
[2015-01-19 17:31:25] |
The meaning of those fields for market statistics is documented here: Sierra Chart Market Statistics: Calculations and Algorithms These would never change no matter how many votes there are. The data stored in those fields must be consistent and common for all symbols. Edit: We will see about adding new market statistics to indicate the number of upticks and down ticks since the last update. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-19 17:34:07
[2015-01-19 17:36:18] |
Edit: We will see about adding new market statistics to indicate the number of upticks and down ticks since the last update. that will help me a lot. thank you very much!
Date Time Of Last Edit: 2015-01-19 17:37:21
[2015-02-03 15:37:51] |
Could you please tell when are you going to discuss those new market stats?
[2015-02-06 17:28:32] |
We will check on this.
