Date/Time: Sun, 22 Dec 2024 16:47:56 +0000
TYPE TEXT
View Count: 849
[2015-01-17 19:56:24] |
User57072 - Posts: 49 |
HOW CAN I TYPE TEXT ON A CHART,AND KEEP IT FROM OVER THE LAPPING THE CHART WHEN DECREASING THE SIZE ?
[2015-01-17 21:03:20] |
Decreasing the size of what?
[2015-01-18 02:35:08] |
NOT SURE IF YOU MY QUESTION WAS NOT ANSWERED BECAUSE I AM NOT A REGISTERED USER, BECAUSE I AM.
[2015-01-18 06:18:26] |
We do not fully understand the question.
