Date/Time: Sun, 22 Dec 2024 20:58:27 +0000
Pivot points variable period study question
View Count: 850
[2015-01-17 10:30:49] |
User11942 - Posts: 298 |
Hello SC team, I noticed that when I change chart type with that study running (let's say time-based to true range), all levels of the study usually get shifted (e.g. 60 min period in study parameters). The question is how is the study calculated when applied to range bars, volume bars etc? Thank you. Date Time Of Last Edit: 2015-01-17 10:50:58
[2015-01-17 22:36:57] |
Refer to the documentation about this here: https://www.sierrachart.com/index.php?page=doc/helpdetails65.html#h65.7 There is no change with the study calculations. The problem is you are changing the bars to non-stable bars. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
