Date/Time: Sat, 28 Nov 2026 03:00:39 +0000
Plotting average price with LMAX
View Count: 1230
| [2015-01-17 06:08:24] |
| User543667 - Posts: 9 |
Hello In the user manual it states that for forex last price, the average of bid and ask is used instead because there is no trade data. My question is, is this the same for LMAX considering they do supply trade information. Cheers |
| [2015-01-17 22:33:52] |
Yes it is the same for LMAX. And LMAX does not provide anything other than bid and ask data on the FIX connection.
| [2015-01-18 09:11:40] |
Ok thanks
