Date/Time: Sat, 13 Sep 2025 04:46:09 +0000
Tool: Extending Rectangle
View Count: 1626
[2015-01-16 21:37:49] |
QnReally - Posts: 188 |
I draw Extending Rectangles of varying width using ACSIL. There seems to be a floor on the smallest height I can draw the rectangle with. If I specify anything smaller than that it just draws the rectangle with the default minimum height. Is this configurable? If not it would help me if you are able to reduce it in the software. This default setting seems to be not affected by the setting "Adjust Tool Values to Tick Size" being off or on. Thanks. |
[2015-01-17 23:11:32] |
Is the smallest height equivalent to the tick size? Provide an image of the chart showing the rectangle, by following these instructions: http://www.sierrachart.com/index.php?l=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-17 23:11:42
[2015-01-18 00:31:58] |
The smallest height on my trading chart is good. The height matches the tick size pretty closely. That chart has every tick shown on the value scale, so it is pretty stretched out (on a 1080p screen there are about 100 ticks shown). However, on various other kinds of charts with varying zoom levels on the y-scale, the height is easily many ticks. No matter how much I zoom in or zoom out on the price scale I don't ever seem to get the height to fall below 6 pixels. I would love to get that down to 2 pixels, if possible. Thanks. PS: The upload function not working at the moment. I can upload the chart example a little later. Date Time Of Last Edit: 2015-01-18 00:41:43
[2015-01-18 15:14:08] |
http://www.sierrachart.com/image.php?l=1421593965705.png |
[2015-01-19 17:55:29] |
This will be solved in the next release.
