Date/Time: Wed, 09 Sep 2026 02:26:12 +0000
Saved Charbook
View Count: 1470
| [2015-01-16 14:40:23] |
| JamesP - Posts: 89 |
I have my settings at auto save chartbook every 30 minutes. I recently upgraded to a new version but when I opened my chartbook the saved version is from quite awhile ago. The backup chartbook is also the older version. Any ideas why this happened and if I can access the most recent saved chartbook?
| [2015-01-16 15:04:09] |
Possibly you installed Sierra Chart into a different folder. This is the most relevant help topic about this: Missing Files After Upgrading Software Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-01-16 15:38:25] |
Thank you.
