Date/Time: Sun, 22 Dec 2024 21:02:13 +0000
data feed XP
View Count: 1017
[2015-01-16 09:28:31] |
User62940 - Posts: 15 |
I forgot yo ask you if your data feed is compatible with windows xp thanks |
[2015-01-16 09:48:09] |
Sierra Chart does work on Windows XP. The only exception is you cannot use the Rithmic Trading service on Windows XP.
