Date/Time: Fri, 22 Nov 2024 14:27:25 +0000
Close Position Button missing
View Count: 1661
[2013-05-22 17:48:22] |
Ema - Posts: 4 |
I am not able to find or submit close position (close all positions) button or menu item in SierraChart platform. Buttons "Flatten" and "Cancel All" do not work as I wish, namely, closing open and filled orders, such as MARKET order together with STOP order submited to TWS platform of IB. There is such a button in TWS and I do close positions created in SierraChart Trading Window using "Close Position" button in TWS. Can you help me with my query? Thanks.
[2013-05-22 20:33:16] |
It sounds as though you want to use Flatten. It is not clear what you want to do differently than this. Do you want to flatten all of your positions at once? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
