Date/Time: Sun, 22 Dec 2024 20:35:06 +0000
Volume by Price MTD
View Count: 848
[2015-01-16 00:00:55] |
User121729 - Posts: 37 |
I am trying to get a Volume by Price graph at far right for a month to date chart. I can get the chart, but the profile has large gaps in it.. It is for ES and the gaps are 2 points or so and I know volume has traded at those prices. What must I change ot get in to fill in at all prices? Thanks |
[2015-01-16 04:25:40] |
The procedure to troubleshoot a problem like this is to remove the Volume by Price study from the chart, and set the chart bars to 1 minute per bar and locate any missing data. If there is missing data, refer to this page here: https://www.sierrachart.com/index.php?page=doc/doc_HistoricalIntradayData.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
