Date/Time: Sun, 22 Dec 2024 20:41:01 +0000
Urgent - Cannot Connect to TDA Data Service
View Count: 847
[2015-01-15 20:00:49] |
LadyTrader - Posts: 19 |
The last time I had live data was at 14:15EST today. Not sure why the data dropped and won't reconnect - it keeps trying to reconnect without any completion. I completely shut the computer down and restarted but still will not reconnect. Help please - Thanks |
[2015-01-15 20:01:28] |
Yes we know about this and TD Ameritrade has been contacted.
