Date/Time: Thu, 16 Jan 2025 05:46:05 +0000
Data Trade settings related question - Allow Server to drop data
View Count: 1073
[2015-01-15 15:35:29] |
ejtrader - Posts: 688 |
SC Team - I tried to locate the meaning of the option "Allow Server to Drop data" under data/Trade service settings. Would you please explain what this option is supposed to do? thanks |
[2015-01-15 17:24:44] |
It is a CQG specific option. We understand that if the CQG server senses the client-side is not processing data fast enough, it will drop some data.
[2017-10-17 19:51:15] |
Luke - Posts: 142 |
Wouldn´t that mean that intraday charts are inaccurate if data is missing?
[2017-10-18 00:31:45] |
Yes that does make sense. If you want the best data feed use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
