Date/Time: Sun, 22 Dec 2024 20:10:34 +0000
New Installation on a New Computer
View Count: 867
[2015-01-15 15:20:31] |
Fxxtrader - Posts: 79 |
Hello, I got a new computer and downloaded SC on it. I followed the steps here (http://www.sierrachart.com/index.php?page=doc/helpdetails15.html) to bring over my chart layouts and settings including my assigned keyboard shortcuts. It all works fine except my custom setting for each tool did not come over including the 1-8 custom configuration. How do I bring over my custom tool settings over from the old installation to the new installation or do I have to redo them all? Thanks, |
[2015-01-15 17:23:54] |
When you are copying the files make sure that neither copy of Sierra Chart is running and for the tool settings you need to copy Sierra3.CFG.
