Date/Time: Wed, 16 Sep 2026 09:33:35 +0000
WAITING TO RECONECT
View Count: 1401
| [2015-01-15 12:52:21] |
| User462306 - Posts: 3 |
I HAVE AMP TTNET SCacount today when i receive a message to update, i did it but i change the location to a new folder, now, it can see wait to reconect error us or pasw i setup everything again and the same |
| [2015-01-15 16:53:07] |
If you are having a problem doing something with Sierra Chart, then please copy and paste the ENTIRE copy of the Message Log into your email message or Support Board message. Support cannot help without the Message Log. Sending some of the lines is not helpful. The message log does not contain any private information. Instructions: 1. If the Sierra Chart Message Log is not already open, then select "Window >> Show/Hide Message Log" on the menu to open it. If you still do not see the log after selecting this command, then select "Window >> Reset Windows". The log will be displayed in this case. If not, then select "Window >> Show/Hide Message Log" again. 2. Press the "Copy Log" button on the Message Log window. Do not use the "Send for Analysis" button. Otherwise, the log will not be seen. 3. Go to your e-mail message or your Support Board message. Point to the area where you type your message. 4. Right-click your mouse pointer. Select "Paste" on the menu to paste it into the message. THE INSTRUCTIONS ABOVE EXPLAIN HOW TO AUTOMATICALLY COPY AND PASTE THE MESSAGE LOG DATA INTO A MESSAGE. THERE IS NO NEED TO TYPE IT BY HAND. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
