Date/Time: Mon, 05 Oct 2026 07:21:41 +0000
Euronext Futures Indices: Price 57.75 USD/month.
View Count: 1325
| [2015-01-15 10:53:27] |
| User62940 - Posts: 15 |
Hi Is this data feed include Market Depth ? I mean is it compatible with my package 5 and can I use studies like volume profile, footprint, is it a top-quality and low latency data feed that provides tick by tick data to trade the future cac 40 ? many thanks |
| [2015-01-15 17:19:26] |
Yes. Market depth is included. It is a good quality data feed. Not totally certain about the latency if you are looking for latency under a few milliseconds. The latency probably would be over 200 ms. But it has not been measured. Here is a chart image of the CAC 40: http://www.sierrachart.com/image.php?l=1421342221659.png Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
