Date/Time: Mon, 21 Sep 2026 08:38:45 +0000
LMax New Connection
View Count: 2191
[2015-01-15 04:51:44]
User78442 - Posts: 260
I recently installed a new copy of SC. I tried to access a working LMax Fix account but can't logon. It says Bad Credentials - I know the logon is ok as I can access it via the web and other SC instances. Any ideas;
LMAX Trading | Connecting. | 2015-01-15 04:48:28
LMAX Trading | Connecting to Demo Trade server: fix-ate.lmaxtrader.com:443 | 2015-01-15 04:48:28
LMAX FIX Trading socket (0) | Resolved address fix-ate.lmaxtrader.com to IP 91.215.165.68 | 2015-01-15 04:48:28
LMAX FIX Trading socket (31) | Connected. | 2015-01-15 04:48:28
LMAX FIX Trading socket (31) | Starting SSL connection. | 2015-01-15 04:48:28
LMAX FIX Trading socket (31) | SSL connection established. | 2015-01-15 04:48:28
LMAX FIX Trading: Sending the Logon message. | 2015-01-15 04:48:29
LMAX FIX Trading: Received a Logout message. Text = BAD_CREDENTIALS | 2015-01-15 04:48:29
LMAX FIX Trading: Sending a Logout message. Text = Received Logout message. | 2015-01-15 04:48:29
LMAX FIX Trading socket (31) | SSL shutdown indicates not able to send 'close notify'. | 2015-01-15 04:48:29
LMAX FIX Trading socket (31) | SSL has been shut down. | 2015-01-15 04:48:29
LMAX FIX Trading socket (31) | SSL object has been freed. SSL state is now disconnected. | 2015-01-15 04:48:29
LMAX FIX Trading socket (31) | Shutdown and closed. | 2015-01-15 04:48:29
LMAX FIX Trading: Logged out and disconnected. | 2015-01-15 04:48:29
Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2015-01-15 04:48:29
To prevent further connection attempts, select 'File >> Disconnect'. | 2015-01-15 04:48:29
LMAX FIX Trading: DisconnectFIX called. | 2015-01-15 04:48:29
LMAX Trading | Disconnected from trade and market data servers. | 2015-01-15 04:48:29
Will reconnect to the server in 5.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2015-01-15 04:48:29
File >> Disconnect selected. | 2015-01-15 04:48:32
LMAX FIX Trading: DisconnectFIX called. | 2015-01-15 04:48:32
LMAX Trading | Disconnected from trade and market data servers. | 2015-01-15 04:48:32
[2015-01-15 04:53:52]
You will need to ask LMAX, why they are sending this message:
Make sure the LMAX Username you are using is allowed to use the FIX server.
[2015-01-15 05:08:59]
I can logon via another instance of SC.
[2015-01-15 06:45:51]
Check your LMAX Username and Password in Global Settings >>Data/Trade Service Settings to make sure they are correct.
