Date/Time: Tue, 22 Sep 2026 14:17:28 +0000
LMAX inactivity fee
View Count: 1389
| [2015-01-15 04:14:54] |
| User543667 - Posts: 9 |
Hello Just wondering if the required 12.5 million in order to not incur the $100 dollar fee is round trip or total. In other words if I open a trade for 1 million and then close it does this count for 1mil or 2 toward my volume? Cheers |
| [2015-01-15 04:54:20] |
We would think this would count as 2,000,000. We will check for you.
| [2015-01-15 05:48:47] |
According to LMAX, it looks like the answer to your question is 1,000,000 because they said this: That would be 25 million in order to avoid the inactivity fee. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-01-15 05:51:17] |
Ok thanks for the quick reply. Have they given you reason as to why they charge this fee?
