Date/Time: Mon, 30 Nov 2026 03:51:51 +0000
Finite amount of space
View Count: 1198
| [2015-01-14 22:11:19] |
| User20214 - Posts: 24 |
Hi, Quick question: Is there a finite amount of space in the Alert Condition Box? My alert equation is truncated near the end of the 4th line and I could not key in another character -- thus creating an error in syntax. Thanks |
| [2015-01-14 23:08:57] |
Yes there is. In this case you need to use Spreadsheet System/Alert study: http://www.sierrachart.com/index.php?page=doc/doc_SystemsAlerts.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
