Date/Time: Sun, 22 Dec 2024 20:09:44 +0000
Problem with Stoplimit Order
View Count: 969
[2015-01-14 19:12:58] |
Luke - Posts: 142 |
When I have an open position with an attached stopmarket order, and I add a stoplimit order at the same pricelevel as the stopmarket order (to reverse the position), the stoplimit order often gets canceled once the stopmarket order is hit. how can this be avoided? The problem doesn´t occur if the stoplimit is placed further away than the attached stopmarket order.
[2015-01-15 02:35:39] |
What is the reason the order is being canceled? You will see the reason in the Trade Activity Log. Refer to the instructions here: https://www.sierrachart.com/index.php?page=doc/doc_TradeActivityLog.php#ViewingHistoricalTA Look at the Order Action Source column. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
