Date/Time: Sat, 15 Mar 2025 07:53:30 +0000
Spreadsheet System vs. ACSIL
View Count: 1445
[2015-01-14 16:12:28] |
User51760 - Posts: 108 |
Hello Support Team, trying to dig into building an automated system for backtesting purposes I wonder what tool to start with and concentrate on: either the Spreadsheet System for Trading or an ACSIL Study. Is there a Link or place somewhere in the documentation discussing Spreadsheets vs. ACSIL? Thank you for your consideration and pointing into the right direction, Best, Chris |
[2015-01-14 18:55:42] |
ACSIL is going to give you more flexibility and will be faster. So that is the preferred method but it can be more difficult. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-14 18:55:59
[2022-07-19 05:56:51] |
sourdubber - Posts: 52 |
Can you elaborate? Just how much faster? Is it noticeably faster? Has there been a performance benchmarking between the two?
[2022-07-19 08:47:37] |
ACSIL will be dramatically faster. It depends upon exactly what is being done. It can easily be 10 times or 50 times faster.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2022-07-19 08:47:52
