Date/Time: Tue, 29 Sep 2026 00:51:11 +0000
Multiple Stocks in One Chart with Equivolume Bars
View Count: 2641
[2015-01-14 15:29:03]
User76865 - Posts: 4
In another charting service I can put up to around 12 different
stocks symbols into the symbols box just using plus
signs between them and it gives me one chart that
is the combination of those 12 stocks (not 12 different
charts overlayed--but just one chart that represents
the basket of all 12). And it works with equivolume bars.
Can I do this same thing in Sierra Charts? And if so,
what is the limit on the number of stocks I can put
into one chart? And how do I go about doing that?
Thank you
[2015-01-14 17:41:03]
This can be done with the Sum Charts From List study:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s228
You can set the Graph Draw Type to Price Volume Bars for the study through the Study Settings window:
Chart Studies: Study Settings Window
