Date/Time: Sun, 22 Dec 2024 20:43:08 +0000
line drawed could be only visible in the special timeframe
View Count: 908
[2015-01-14 13:37:57]
User17064 - Posts: 70
Hi SC support,
I would ask is there any way to let the line only show in its timeframe and the timeframe lower than it?
For example, the line I draw in 1 hour timeframe could only be visible in hour timeframe and any timeframe lower than it. When I switch to 4H or Daily timeframe. that line could not be viewed.
Is that possible?
[2015-01-14 17:34:11]
No, this is not supported and there are no plans for something like this.
Date Time Of Last Edit: 2015-01-14 17:37:10
[2015-01-15 01:43:20]
But if do not support this function. The line or zone I draw in lowertimeframe, when I switch to HTF, there are massive line on the chart and this will definitely affect the analysis. Hope it could be supported in next generation
