Date/Time: Mon, 14 Sep 2026 01:53:02 +0000
Multiple Stocks in One Chart with Equivolume Bars
View Count: 1624
| [2015-01-14 06:16:34] |
| User76865 - Posts: 4 |
Hi, In another charting service I can have a single chart with up to 12 different stocks in it. I do this by simply putting a plus "+" sign between the symbols. It gives me one chart that is the combination of those 12 stocks (not 12 different charts overlayed--but just one chart that represents the basket of all 12). And it works with equivolume bars. Can I do this same thing in Sierra Charts? And if so, what is the limit on the number of stocks I can put into one chart? And how do I go about doing that? Thank you |
| [2015-01-14 17:42:46] |
This has been answered here: Multiple Stocks in One Chart with Equivolume Bars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
