Date/Time: Tue, 15 Sep 2026 04:37:48 +0000
How much data is there above Package 3 for Re-Play Chart?!
View Count: 1248
| [2015-01-14 01:23:25] |
| CaseyWang - Posts: 13 |
I know almost 1 month data for free-trial to Chart Replay. How much data will be provide above Package 3 & P5 ?! If I just would like to paper trade Real Time ES(E6),how much charge will I pay?! Thanks |
| [2015-01-14 04:20:47] |
So you want real-time futures data? There is an alternative to this which is much less expensive if you do not have a trading account. Refer to: https://www.sierrachart.com/index.php?page=doc/data.php#AltToFuturesData For the Alternative to Futures data you only need Sierra Chart Service Package 1. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-01-14 05:36:12] |
The alternative provides how long Historical data?!
| [2015-01-14 20:19:50] |
It depends upon the symbol. For example the SPX500 symbol (cash market equivalent to ES futures) has data back to 2011-01-02.
