Date/Time: Sun, 15 Mar 2026 22:38:02 +0000
Position Quantity study frequently wrong in simulation mode
View Count: 1472
| [2015-01-13 15:31:57] |
| User87744 - Posts: 22 |
Hi, As per message title, I have found that the "position quantity" study frequently fails to update when I enter and exit a trade in "trade simulation mode". Sometimes, I enter a new position but it will still be printing zero. Other times, when after i have closed a position it will still be printing my original contract position. I have tried checking and un-checking "use order fill calculation" and it has made little difference. Please help. |
| [2015-01-13 18:00:29] |
Refer to this section here about this: https://www.sierrachart.com/index.php?page=doc/doc_TradeStatusWindows.html#TradeDataStudiedNoDataMisaligned It is a new section we added, so reload the page if you do not see it. We suspect your computer's clock is not set correctly. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-13 18:00:46
