Date/Time: Sun, 22 Dec 2024 10:29:20 +0000
Text on eg Rectangle
View Count: 879
[2015-01-13 14:20:31] |
AKR - Posts: 523 |
Would it be possible to split the alignment of price lables and text. So I would love to have the price labels on the right and any text I enter on the left. Reason is that I type quite some text sometimes and that is bothering me on the right side. But I prefer prices on left and anyway both at same place is also too much sometimes. Just a "nice to have", but probably not much work for you?? Thx!! |
[2015-01-13 21:52:44] |
We are going to see about this.
[2015-02-10 16:19:18] |
Al SC Developer - Posts: 434 |
In the next version, there will be a new drawing option for rectangle and extended rectangle drawings to "Split Text Opposite Of Labels".
