Date/Time: Fri, 22 Nov 2024 14:18:52 +0000
Daily profit & loss and other statistics
View Count: 1702
[2013-05-22 12:24:06] |
flyboy615 - Posts: 56 |
Hi, Is there a way to get stats for an automated study for things like daily consecutive losses, daily loss that are directly associated with the study or at lease the chart? Thanks |
[2013-05-23 05:22:01] |
Yes. Refer to: http://www.sierrachart.com/index.php?l=doc/doc_ACSIL_Members.html#scGetTradeStatisticsForSymbol Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
