Date/Time: Sat, 26 Sep 2026 21:24:36 +0000
Trading Dome & Chart attachment;
View Count: 1598
| [2015-01-12 23:24:46] |
| User22591 - Posts: 133 |
I have a Trading window and trading dome set up for option trading with option figures. Can I attach a chart to this setup? Can you explain for me how to read the dome for trading PUT or direct me to an area in your Document where it might be explained. Usually in trading Puts as the STOCK price goes down the option price goes UP. Is this the case with the dome that the option price increase or move up. There are two background color shades on the dome do they have some importance? Thank Winston Date Time Of Last Edit: 2015-01-17 19:31:42
| [2015-01-20 20:55:39] |
What you need to do is open a chart using that same option symbol. Open a chart through File >> Find Symbol and manually type in the option symbol into the Selected Symbol box. After that, enable chart trading for the chart. Follow the instructions here: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#ChartTrading The Trading DOM will show the current option price with a ladder of prices above and below that price. Refer to the documentation here for the chart/Trade DOM colors: http://www.sierrachart.com/index.php?page=doc/doc_ChartTrading.html#CustomizingGraphics The two colors you referring to are the colors above and below the midpoint of the bid and ask. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
