Date/Time: Sun, 22 Dec 2024 21:35:23 +0000
Sierra chart datafeed - Interactive Brokers
View Count: 890
[2015-01-12 21:39:18] |
User27439 - Posts: 11 |
Hi there, I have a problem to set my datafeed. I would like to use real time sierra chart data in my charts and be able to give orders from these charts at the same time to my broker (Interactive Brokers). Could you navigate me how to do it, please? I installed two copies of sierra chart and tried to do it according to instructions in the link below but i did not succeeded. Using Multiple Data and Trading Services at the Same Time thanks for your help |
[2015-01-12 23:20:35] |
There is no special set up required for this. You only use one copy of Sierra Chart and set it to use Interactive Brokers. This is explained here: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Integration Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
