Date/Time: Sun, 22 Dec 2024 21:53:58 +0000
Line Study in Trading DOM
View Count: 902
[2015-01-12 21:25:03]
AC95501 - Posts: 28
Dear SC-Community,
I tried to add the Line Study to the Trading DOM, but the Text Column doesn't show up at the value I set it to.
Can anyone help me there?
Best regards
Max
imageLine Study.png / V - Attached On 2015-01-12 21:24:59 UTC - Size: 104.76 KB - 337 views
[2015-01-12 22:56:27]
You need to enable the Subgraph >> Value Label for the Line:
https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#NameValueLabels
[2015-01-12 23:24:38]
AC95501 - Posts: 28
I had to scale it Same as Region an it worked then.
Thanks anyway for great support.
