Date/Time: Sun, 22 Dec 2024 21:57:17 +0000
Show the higher timeframe candle in lower timeframe
View Count: 2785
[2015-01-12 09:07:16] |
User17064 - Posts: 70 |
Hi SC support, Is there any indicator could help to show the higher timeframe candle in lower timeframe chart? For example, if I use 15M chart, I would like to have 4H candle could show in the chart also. Please check the attached |
Capture.JPG / V - Attached On 2015-01-12 09:07:06 UTC - Size: 18.68 KB - 974 views Attachment Deleted. |
[2015-01-12 09:20:35] |
The closest Sierra Chart offers to this is the Study/Price Overlay study: Http://www.sierrachart.com/index.php?page=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-12 13:52:14] |
Sawtooth - Posts: 4141 |
Take a look at the user-contributed NMinBars study from Kiwi: Analysis >> Studies >> Add Custom Study button >> User Contributed Studies >> NMinBars |
[2015-01-13 05:16:30] |
Thanks a lot for your help! Btw @tomgilb, the study you said will be better if it could provide the tail on top and bottom both. Seems it only has the shape of the range not the candle pattern. |
