Date/Time: Sun, 22 Dec 2024 21:51:49 +0000
Looking for a specific function.
View Count: 856
[2015-01-11 22:36:45] |
User48557 - Posts: 138 |
Is there a way to delete all the trend lines that i manually draw on the chart? But.. I would like my indicators to stay. I noticed there is a function that deletes everything on the chart including the indicators, In this case i would like to keep the indicators and just get rid of the lines.
[2015-01-11 23:53:20] |
You can delete all the Chart Drawings except for the text drawings with Tools >> Erase All Nontext Drawings.
