Date/Time: Sun, 22 Dec 2024 21:31:25 +0000
How to move chart by Hand Tool
View Count: 6352
[2015-01-11 15:13:33]
User57111 - Posts: 25
I use Hand Tool but when I grab the chart I can only move it left or right.
I want to grab the chart and move it every direction also up and down.
How can I do it?
Best regards,
Rafal
[2015-01-11 15:50:23]
Sawtooth - Posts: 4141
These are the settings I use, and it does what you want:
-Global Settings >> Tool Settings >> General Tab >> After Single Tool Use Change To: Hand
-Global Settings >> Tool Settings >> General Tab >> and check 'Support Vertical Scaling/Movement With Hand Tool
-Global Settings >> Tool Settings >> Chart Values tab >> and check 'Always On When Using Other Tools'
[2015-01-11 16:35:18]
thanks
these are the great setting for me.
I have one more question because I use volume
but this scale is locked. In price chart I can change it.
Is it possible to unlocked volume scale so I can move it and expand it?
[2015-01-11 18:51:26]
Refer to the documentation here for the Hand tool:
https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#Hand
Set the Scale Range for the Volume study to "Automatic":
https://www.sierrachart.com/index.php?page=doc/doc_Scaling.html#ScaleWindowStudy
[2015-01-11 19:03:09]
It's OK
thank you
