Date/Time: Tue, 15 Sep 2026 08:11:35 +0000
Historical Data
View Count: 1274
| [2015-01-11 02:43:17] |
| User78926 - Posts: 69 |
Hi there, I am on Service Package 3 and can not figure out how to get historical data into my charts [with FXCM] I have changed the 'Use Date Range' in Chart Settings to go back 5 years for Daily candles for USOil, it does go back but only to June 2014. Can you please assist? Rgds, Mark |
| [2015-01-11 04:50:59] |
With certain FXCM CFD symbols, there is limited historical daily data available for them. For US Oil we recommend using CL# for a historical Daily chart to get the equivalent futures data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2015-01-15 05:51:21] |
..thx for your response, sorry I'm a bit confused; where do I get CL [Oil Futures] data from? I have looked in 'Find Symbol' not there, 'New/Open Historical Chart' only shows 4 FX symbols. Is it a paid service from FXCM? Rgds, Mark |
| [2015-01-15 09:57:53] |
You need to manually type the symbol into File >> Find Symbol >> Selected Symbol and press Open Historical Chart.
