Date/Time: Sun, 22 Dec 2024 21:23:48 +0000
Connection
View Count: 963
[2015-01-10 18:36:52] |
User82486 - Posts: 43 |
My broker is Interactive Brokers I am logged in to both a "live" platform and a "Simulated" platform at the same time. I want to connect one instance of Sierra with the "Live" platform for my futures trading and I would like to connect another Sierra to the Simulated platform. I can get both of these to work but only one at a time and I have to change THE PORT id EACH TIME I WOULD GREATLY BENEFIT BY HAVING BOTH UP AT THE SAME TIME SO i CAN PLACE L;IVE FUTURES TRADES AND ALSO TEST OUT SOME STRATEGIES ON MY STOCK TRADING. Sorry for the climsy typing Fred |
[2015-01-12 06:11:42] |
So it sounds like you have two copies of Trader Workstation running and you understand how to set the connection port number for each. For additional reference on this, refer to this page here: https://www.sierrachart.com/index.php?page=doc/IB.php#MultipleTWSInstances You need to install two copies of Sierra Chart on your system. Each one will be set to use a different port number to connect to Interactive Brokers Trader Workstation. This is documented here: Using Multiple Data and Trading Services at the Same Time: Step-By-Step Instructions to Install Multiple Copies of Sierra Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-12 06:12:29
