Date/Time: Sun, 22 Dec 2024 20:46:01 +0000
Question regarding new spreadsheets
View Count: 869
[2015-01-09 19:44:26] |
George - Posts: 60 |
Since the columns A thru G never change, is it alright to use b3 instead of id0.sg1@3? I know that it works, but I suspect that the performance may suffer, does anyone know?
[2015-01-09 19:50:51] |
Yes, this will be fine.
