Date/Time: Sun, 22 Dec 2024 22:03:27 +0000
Data Download
View Count: 865
[2015-01-09 17:19:26] |
User22591 - Posts: 133 |
I am having very long delay in the downloading of Historical Charts. Is there an issue on your on your side?
[2015-01-11 04:57:29] |
This would be an issue with Interactive Brokers when using Interactive Brokers. Refer to this section here for help with this: http://www.sierrachart.com/index.php?page=doc/IB.php#SlowDownloading Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-11 05:12:13
[2015-01-11 05:11:46] |
2 corrections were made to the prior post. Reload the page for the updated content.
