Date/Time: Sun, 22 Dec 2024 20:56:04 +0000
[User Discussion] - How to make candle bars up hollow and filled when using an indicator to color them
View Count: 1704
[2015-01-09 16:17:25] |
Carl71 - Posts: 125 |
How to make candle bars up hollow and filled when using an indicator to color them Please see the image attached Date Time Of Last Edit: 2015-01-09 16:18:02
Color bars.png / V - Attached On 2015-01-09 16:17:20 UTC - Size: 123.22 KB - 475 views |
[2015-01-09 16:43:06] |
I mean a thing like this Attached file made with photoshop |
COLOR BARS EXAMPLE.png / V - Attached On 2015-01-09 16:43:04 UTC - Size: 30.69 KB - 524 views |
[2015-01-09 17:45:10] |
Have a look at using Color Bar Candle Fill: https://www.sierrachart.com/index.php?page=doc/doc_ChartStudies.html#DrawStyle Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2015-01-09 18:00:39] |
I am not familiar with ACSIL... How about to create into draw style the following: Color Bar Hollow Up Color Bar Hollow Down Color Bar Up Fill Color Bar Down Fill |
