Date/Time: Sat, 12 Sep 2026 08:57:54 +0000
File MenuCutomizations.xml not recognized
View Count: 1535
| [2015-01-09 15:32:55] |
| User51760 - Posts: 108 |
Hello Support Team, since some time I am in the process of translating all menu commands into German. Everything worked fine and there is a file MenuCustomization.xml On continuing with the translation today the xml-file is not recognized anymore. The file contains all translations and seems to be uncorrupted, but on starting SC there are no German menu commands anymore but the English version. On going through Global Settings >> Customize Menu Items no translation shows up. The file MenuCustomization.xml resides in C:\SierraChart. I am attaching the file to this post. Any ideas how to get the file to work? Don“t want to loose a lot of work since I planned on sharing the translation with Sierra Chart and other users. Best, Chris Date Time Of Last Edit: 2015-01-09 19:05:00
Private File |
| [2015-01-09 19:11:21] |
The translations cannot contain the " character. Check the document here: http://validator.w3.org/check This will help you find whatever problems there are. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2015-01-09 19:11:40
