Date/Time: Sun, 22 Dec 2024 20:31:39 +0000
Applying my credits elsewhere
View Count: 892
[2015-01-08 19:23:45] |
User33195 - Posts: 1 |
When I was on trial I added funds via Paypal and I see that was applied to the additional services section. I didnt really understand what I was doing then, is there a way this amount could be applied to a subscription?
[2015-01-08 20:28:36] |
Yes. Within Sierra Chart select Help >> Add Usage Credit. You will see an option on the webpage to pay from the Additional Services Balance. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
