Date/Time: Sun, 22 Dec 2024 21:37:12 +0000
Please add the Hand tool to the drop down menu when we right click on a chart
View Count: 1119
[2015-01-08 19:10:08] |
User40520 - Posts: 62 |
I have a lot of monitors and when I use the hand tool I can right click on the chart and select the Crosshair which is very convenient. However it's not so convenient that I can't toggle between the hand and the Crosshair. It makes a little difference when using two monitors but a lot of difference using 12 and only one selection is available on right click. Thanks. |
[2015-01-08 19:41:49] |
Sawtooth - Posts: 4141 |
These are the settings I use, and it does what you want: -Global Settings >> Tool Settings >> General Tab >> After Single Tool Use Change To: Hand -Global Settings >> Tool Settings >> General Tab >> and check 'Support Vertical Scaling/Movement With Hand Tool -Global Settings >> Tool Settings >> Chart Values tab >> and check 'Always On When Using Other Tools' |
[2015-01-08 20:32:26] |
That worked perfectly :)
[2015-01-10 05:12:24] |
Refer to: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#CustomizingCDMenu Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
