Date/Time: Sun, 22 Dec 2024 20:34:10 +0000
Question with TransAct connection
View Count: 859
[2015-01-08 16:39:14] |
Carl71 - Posts: 125 |
In Data Trade Service Settings the field enable fix login is not flagged It must be flagged?? |
[2015-01-08 17:28:26] |
This is only relevant for FIX connections which TransAct does not use.
